Probably a question for @gchen again
So
supports multiple levels for chunk directory (though by default it is only 1). I can see it might be useful for storages that have some limits on number of entries in a single folder (are there any other use cases for that)? That’s not my question though. I was looking at prune implementation, and there is some non-trivial logic of handling scenarios with redundant chunks, e.g. the same chunk appearing at different levels (so D3/495A8D… and D3/49/5A8D…). The question is, how can it reasonably happen in the normal course of operation (so no one copies files manually etc)? I thought chunk levels are fixed at storage creation, and once they are, a chunk can only go to a single level determined by write level.
So how can something like that happen? Trying to find out why this functionality is needed in prune.
