Not really sure if this is a question for yourself or Backblaze!
if I use Duplicacy with multiple clients but all connected to the same Backblaze B2 are the clients protected from accessing each others data?
Thanks
David
Thanks
David
Multiple clients connecting the the same B2 bucket will be able to access each others data. If you want to avoid that you should assign each client a different bucket.
Great, thanks for explaining.
David
