I need a bit of help. I have setup Duplicacy, but I’m not sure I’ve done it right.
So here’s the scenario.
What to backup:
Windows system, 2 drives (C, D)
Where to backup:
local NAS (Unraid)
Onedrive
Unraid path to Duplicacy storage is /mnt/user/backup/duplicacy/lasse/. This is mapped to Windows as Z:\backup\duplicacy\lasse\.
I prefer to not have additional directories/files created in the repositories. So I used the -repository option. I was not able to init both repositories from Z:\backup\duplicacy\lasse\ so I created a directory for each repository. From these I did something like
Z:\backup\duplicacy\lasse\lasse_c> duplicacy init -storage-name unraid -repository c:\ lasse_c Z:\backup\duplicacy\lasse\
Z:\backup\duplicacy\lasse\lasse_d> duplicacy init -storage-name unraid -repository d:\ lasse_d Z:\backup\duplicacy\lasse\
I ran both backups once. I then tried to add Onedrive as secondary storage. This again gave me troubles, especially since I want the copying to be executed on the Unraid server. I ended up duplicating the unraid storage entry in the preferences file and modifying its paths to local paths. I was then able to add Onedrive as storage.
duplicacy add -e -copy unraid-local onedrive lasse_d one://backup/lasse
Strangly, even thou I was in /mnt/user/backup/duplicacy/lasse/lasse_d/, the onedrive entry was added to the preferences file under /mnt/user/backup/duplicacy/lasse/lasse_c/. I then just copied the entry to the second preferences file.
I saw the thread about dummy repository when copying, but I didn’t quite get it.
I now have the copying running, but I’m not sure whether it’s copying just one of the reposities or both.
