is there an easy option to check wheter a backup run was successful with nagios check_mk.
This is something new to me. I’ll take a look but at this time there is no immediate plan to support check_mk.
Thanks for your quick anwser. I dont expect to support this tool. In general check_mk allows to write own test. The main question is what should be tested.
Example:
I am running weekly and daily backup jobs.I am pretty sure that for each backup job files are written to the machine which executes these jobs. So a basic check could check the existence of a file or read a file and compare it to a given string. It would be good to have a generic solution so that the check dont have to be changed for each new backup job.
