Backing-up to a local drive works great. But after a few days, my initial backup to B2 is not progressing. After running for several hours, I have logs that only account for a few minutes; and the time-remaining clock keep going backwards (up).
Here is a very typical log (a few lines deleted to fit required length):
Running backup command from /home/lance/.duplicacy-web/repositories/localhost/0 to back up /home/lance
Options: [-log backup -storage Lance-Desktop -stats]
2019-12-11 22:36:10.857 INFO REPOSITORY_SET Repository set to /home/lance
2019-12-11 22:36:10.857 INFO STORAGE_SET Storage set to b2://Duplicacy-Haverkamp
2019-12-11 22:36:11.912 INFO BACKUP_START No previous backup found
2019-12-11 22:36:11.912 INFO BACKUP_INDEXING Indexing /home/lance
2019-12-11 22:36:11.912 INFO SNAPSHOT_FILTER Parsing filter file /home/lance/.duplicacy-web/repositories/localhost/0/.duplicacy/filters
2019-12-11 22:36:11.913 INFO SNAPSHOT_FILTER Loaded 7 include/exclude pattern(s)
2019-12-11 22:36:12.000 WARN LIST_FAILURE Failed to list subdirectory: open /home/lance/.cache/dconf: permission denied
2019-12-11 22:36:13.065 WARN LIST_SKIP Skipped non-regular file .local/share/Trash/files/.gnupg-inactive/S.gpg-agent
2019-12-11 22:36:13.155 WARN LIST_SKIP Skipped non-regular file .local/share/parcellite/fifo_c
2019-12-11 22:36:13.155 WARN LIST_SKIP Skipped non-regular file .local/share/parcellite/fifo_cmd
2019-12-11 22:36:13.155 WARN LIST_SKIP Skipped non-regular file .local/share/parcellite/fifo_p
2019-12-11 22:36:13.204 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.009xRo/SS
2019-12-11 22:36:13.204 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.044ocK/SS
2019-12-11 22:36:13.204 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.0Fsmg0/SS
2019-12-11 22:36:13.207 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.19xmxE/SS
2019-12-11 22:36:13.207 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.1JEZ5m/SS
2019-12-11 22:36:13.208 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.2AeUhk/SS
2019-12-11 22:36:13.208 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.2lVXhf/SS
2019-12-11 22:36:13.208 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.2mY22P/SS
2019-12-11 22:36:13.208 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.36XuTR/SS
2019-12-11 22:36:13.210 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.3WNVyP/SS
2019-12-11 22:36:13.210 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.41sqNt/SS
2019-12-11 22:36:13.211 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.4d7oAg/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.5uYA6r/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.6jXWA9/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.6k8e4r/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.6xg3iZ/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.6zWEl1/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.7VCrx4/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.816fCC/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.8HHI8l/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.9LA3BP/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.9V4chp/SS
2019-12-11 22:36:13.213 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.9es4Ht/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.AV8ZuD/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.AWvP86/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.BDjX9n/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.BrzY4m/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Bw0chl/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.CedV7P/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ChAgTC/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ChNQRp/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.D8rfwz/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.DSvdOC/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.DyBZut/SS
2019-12-11 22:36:13.214 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.E34gFH/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.EkjWlK/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.EqLyaG/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.F2IYuy/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.FArG98/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.FUzm2I/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.G3true/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.G73cJt/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.GFWsDc/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.GTJ0L8/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.GteRP3/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.H35cVF/SS
2019-12-11 22:36:13.215 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.HeAfVu/SS
2019-12-11 22:36:13.216 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.I0nB8m/SS
2019-12-11 22:36:13.216 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Iw43xa/SS
2019-12-11 22:36:13.216 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.K5zESI/SS
2019-12-11 22:36:13.216 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.K6BuXl/SS
2019-12-11 22:36:13.217 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.KdKvSv/SS
2019-12-11 22:36:13.217 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Khrjrm/SS
2019-12-11 22:36:13.217 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.LKcHFu/SS
2019-12-11 22:36:13.217 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.LNKT7Z/SS
2019-12-11 22:36:13.217 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Lat8cy/SS
2019-12-11 22:36:13.218 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.NPosse/SS
2019-12-11 22:36:13.218 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.NUyobW/SS
2019-12-11 22:36:13.218 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.O8uRIE/SS
2019-12-11 22:36:13.218 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.OPBGmG/SS
2019-12-11 22:36:13.218 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.OUAfEz/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Oa5x5R/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.OuBFIv/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.PVVU4p/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.PeGdYY/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.PmDvQi/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.QLSOt7/SS
2019-12-11 22:36:13.219 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.QbAwR9/SS
2019-12-11 22:36:13.220 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.S07uWB/SS
2019-12-11 22:36:13.220 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.S1EHPO/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Styj4p/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.THcfKt/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Twpd69/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.U9PQ45/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.UTGuAm/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.UiRd3P/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.V1i8zU/SS
2019-12-11 22:36:13.221 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.V229ch/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.VMAtwn/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.VZhdQB/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.WTIyAk/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.WY0Q6W/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.WlO0Zf/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Wmg8MR/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.YWXNJt/SS
2019-12-11 22:36:13.222 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.YgqHwd/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.YywexB/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.Z6gGFu/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ZXVJ0m/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.a5P0Tn/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.aB4NXA/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.aUCRRg/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.aetl3R/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.afA6Gf/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.aio1XX/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.aoFPhf/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.bH5mAy/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.bpIjes/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.chbcfX/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.e4ZZhz/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.eFuuHt/SS
2019-12-11 22:36:13.223 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.eHOMIB/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.edNLOm/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.efMzJ6/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.f2x9kl/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.fc3mX5/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.fdxEuZ/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.fkKQwx/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.g0YZMz/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.gQmrGn/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.h61nBG/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hC0552/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hEYxpX/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hG3JWP/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hLuwTE/SS
2019-12-11 22:36:13.224 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hVfTnE/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hWEERf/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.hbORFw/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.iRRBMH/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ia8yg0/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.id8xrq/SS
2019-12-11 22:36:13.225 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.jJMRna/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.k9JgY0/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.kRrdBQ/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.khcxFz/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.lMtJNS/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.lSuTPa/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.lxj19t/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.lytHJA/SS
2019-12-11 22:36:13.226 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.m0aJPw/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.m5GSUO/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.m6oqP7/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.mZBbUt/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.mluy58/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.mv7wil/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.n05XTa/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.n2YK5e/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.nHdkJL/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.nYP5M4/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.nlYWDQ/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.npTwM1/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.oEMwka/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.oPyj9n/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.oTrsZa/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.od2CJX/SS
2019-12-11 22:36:13.227 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ot8h3K/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.pGGVCD/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.pQcCnS/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.pTPgzp/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.piMtph/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.qBHPSk/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.qPhWiq/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.quPpRk/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.qyZOkR/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.qzxylS/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.rPY1k0/SS
2019-12-11 22:36:13.228 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.ruZw3L/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.rxY48g/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.s5y7iV/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.sBH9Cn/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.sF6cFj/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.t4rR0s/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.t8M8im/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.tIWtDm/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.tZDqCa/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.tanr6t/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.thGu4r/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.tx2CT6/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.u3JpZ7/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.uBLNDC/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.v3dcS0/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.vDQA4Y/SS
2019-12-11 22:36:13.229 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.vz8qS7/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.w3MZsJ/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.wOmvax/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.wtZFE1/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.x6lhIY/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.xFnaNH/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.xbIw71/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.xqugmY/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.xsdeg2/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.y5tRiC/SS
2019-12-11 22:36:13.230 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.y9nMUk/SS
2019-12-11 22:36:13.231 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.zodv5Z/SS
2019-12-11 22:36:13.231 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.zoxB6j/SS
2019-12-11 22:36:13.231 WARN LIST_SKIP Skipped non-regular file .var/app/org.signal.Signal/cache/.org.chromium.Chromium.zpP931/SS
2019-12-11 22:36:13.318 WARN LIST_SKIP Skipped non-regular file .zoom/data/com.zoom.ipc.assistantapp__req
2019-12-11 22:36:13.318 WARN LIST_SKIP Skipped non-regular file .zoom/data/com.zoom.ipc.assistantapp__res
2019-12-11 22:36:13.540 WARN LIST_SKIP Skipped non-regular file old-.gnupg/S.gpg-agent
2019-12-11 22:36:13.590 INFO BACKUP_LIST Listing all chunks
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1035305840: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1047025558: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1129744804: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1183988422: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1210169957: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1234983728: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1248654688: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1319620836: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1329325812: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1330842592: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1636312809: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1656487678: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1662775564: no such file or directory
2019-12-11 22:40:21.809 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1828357683: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1980021216: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/1985612932: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/2017024553: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/2046885742: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/2052720675: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/2130790732: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/501354602: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/671810576: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/710956122: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/866912053: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/870240747: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/873664271: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/934261090: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/953215053: no such file or directory
2019-12-11 22:40:21.810 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/doomed/979570568: no such file or directory
2019-12-11 22:40:53.324 WARN OPEN_FAILURE Failed to open file for reading: open /home/lance/.cache/mozilla/firefox/j5jv917l.default-release/cache2/entries/0478620BD4B11803F1976C134312F776BF420104: no such file or directory
Duplicacy was aborted
