Hi everyone, my goal is to first backup my files to my internal backup drive, and then copy those files to Backblaze B2. I tried to Google the best method to do this and attempted to make a schedule, although I’m still a bit confused. So any feedback on how I can improve it would be appreciated.
- Every 15 minutes daily.
- Backup my files to hard drive
- Every 2 hours daily
- Copy files from above to cloud.
- Once a day, daily (both running parallel)
- Check HD
- Check cloud
- Prune on HD
- Prune cloud
Questions:
- How do I find out the max number of threads I can use? I’ve used Duplicacy for 2 days so far and haven’t even completed the first copy job yet because it was so slow, until I found out how to change the settings. I changed it to 5 threads and it’s A LOT faster, so regardless I’m happy about the improvement but would like to know how to get the maximum amount of speed.
- After changing the threads as described above, I also noticed that there’s less chunks. It went from something like 65000 to 6600. Is this normal? It’s possible I’m remembering incorrectly but I’m pretty sure I’m not.
- If my files backup to my internal HD while they’re also being copied to the cloud (due to the different time intervals), could this be an issue? Or can it not get messed up from this?
- The computer that I’m using isn’t on all of the time. If I miss the scheduled time for a job, does Duplicacy automatically run it the next time it can? I Googled this and supposedly it does, but (unless I’m mistaken) it didn’t seem like this was happening for me. Is there a setting I have to enable?
Any help is greatly appreciated! Thank you.
