I run duplicacy backup with following command:
duplicacy -d -v backup -stats -threads 4 and then specify path to OneDrive token file.
Backup should be created as expected…
…but instead duplicacy terminates with error:
POST https://duplicacy.com/odb_refresh
GET https://graph.microsoft.com/v1.0/me/drive/root:/duplicacy/td?select=id,name,size,folder
Failed to load the OneDrive storage at odb://duplicacy/td: failed to refresh the access token: 40
0 Unexpected response
