Opendrive with webdav backend
I am using opendrive with webdav backend (DUPLICACY_STORAGE=“webdav://***********@gmail.com@webdav.opendrive.com/Backups”).
The backup works well for a while but getting slower and slower (9MiB/sec -> 3MiB/sec) and eventually fails with several errors like this (and duplicacy process stops):
URL request ‘PUT chunks/33/981a99d02d07b28002ba332e3ac0d82e8ee9cfc9ce1bbaaa65723d44286d24’ returned status code 500
URL request ‘PUT chunks/33/981a99d02d07b28002ba332e3ac0d82e8ee9cfc9ce1bbaaa65723d44286d24’ returned status code 504
I would like to upload 3.9TB data, ~400000 files 10 threads, 32MB avg. chunk size (min/max is default /4, *4), encrypted. Restarting inclomplete backup works (takes few minutes to continue), but after several hours of activity the process fails with similar errors.
I contacted OpenDrive support too, they asked if there is a possibility to fine-tune webdav parameters? e.g. increase timeout value, etc.
Is it possible to set parameters for duplicacy webdav backend? I duplicacy checked docs and found nothing related.
I am also wondering how connections handled in case of multiple threads. Is connection recreated periodically? Or on each upload? Or only once for each thread?
Also I was thinking of mounting webdav as local fuse fs and do a local to local backup instead of local to webdav. Would that be more reliable? I might have more control over webdav parameters.
P.s. running duplicacy on QNAP intel x64 arch linux
500 and 504 are server error and gateway timeout. Those are server side issues; the webdav interface on open drive is beta; and even when it isn’t it’s not the most performant one. Plus open drive have anti-incentive to make large transfer fast – you already paid money – all incentives are to prevent you from using bandwidth and storage.
Fine-tuning and throttling upload would be counterproductive – you would need to back off and throttle to match dying service.
I don’t know – I would not trust any important data to web-dav backend, much less the one still in beta on an “unlimited” service.
OpenDrive “unlimited” plan for personal use offers 10TB storage without any official limitations, 20TB for business users on the same price as Google Drive 2TB storage. I checked other options too: I was able to reach 32 MiB/sec upload speed with duplicacy on Google Drive, but they have no reasonable plan for 4-6-8-10 TBs of data. Previously I used HubiC (still have account for 10 TB), but up/down speed is worse (1/10) with duplicacy compared to OpenDrive. I also tried https://dashboard.blomp.com/ but their swift api is not compatible with duplicacy backend (or duplicacy is not compatible with that - I was not able to set up it working).
So I have tried many options offering 10TB on a reasonable price. I have been using cloud backups for 4 years, no incidents so far. For me it is just an additional safety layer. I dont want to spend huge amount of money on this.
My experience is that during peak hours in the USA the upload speed drops to 1/3 or worse. During the late night/early morning/working hours the up speed is better. Same is true for probablity of 500/504 errors. I restarted duplicacy around 3:30 MST and speed is 6.5 MiB/sec so far. Was 1.7 MiB around 20:00 MST with much more 500/504 errors. So I suspect it is related with server load/uaser activity. I will clarify with OpenDrive support.
Because of above timeout value might be still useful during busy hours. Recreating webdav connection on backup threads might also help. I suspect this is why they asked about possibility to increas timeout or configure reconnect parameters in duplicacy.
My question is still valid: is there any option/switch/param/env variable for duplicacy to control webdav connection params/timeout/retry/etc.?
The number of tries is hardcoded to 8:
You can modify this number and build your own CLI version following instructions here: Installation · gilbertchen/duplicacy Wiki · GitHub
thanks for pointing out the code
currently the backup is running with a stable 5.6 - 5.9 MiB/sec, no errors so far
I suspect OpenDrive support adjusted some values to make this happen
anyway if I experience issues again I will replace hardcoded 8 with an option to overwrite this from parameter (env/command line) - this migh be useful in general for others too in case of less reliable network/backend server
currently my workaround could be enclosing the duplicacy process invocation with a loop and restart in case of exit code >0 (assuming exit code is >0 when not finished with success)
Update:
Several days ago I also managed to complete a full check of my remote backup (-chunks only, ~4 TBs, all was OK). I had further discussion with OpenDrive support and finally they fixed multi-threaded webdav implementation. Now it is stable, no more http errors during up/downloads.
I also tested partial file restore from the backup and that was fast/OK too.
Ever since I daily perform incremental backups (manually now) and speed is around 6-7 MiB/sec.
My next plan is to automate the process (based on forum recommendations regarding this topic).
