Later edit: This is a known issue: Duplicacy 'check' command can be very slow · Issue #397 · gilbertchen/duplicacy · GitHub
I have a GCD storage with around 5TB of data.
Each time i run backup, check or prune duplicacy hangs at the step Listing all chunks for more than 1 hour.
CPU utilisation is 0, network usage is 0, only the RAM usage increases as more chunks are listed from the storage.
I don’t know if all the storages have this issue or it’s just gdrive but is there a way to speedup this step? Maybe (if it’s not used) use batching?
Here’s the first backup of a new repository for reference:
It's a long debug output
./z.exe -d -log backup -stats -threads 20
2019-01-07 12:05:30.124 INFO STORAGE_SET Storage set to gcd://backups/duplicacy
2019-01-07 12:05:30.124 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_GCD_TOKEN
2019-01-07 12:05:30.125 DEBUG PASSWORD_PREFERENCE Reading gcd_token from preferences
2019-01-07 12:05:33.072 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_GCD_TOKEN
2019-01-07 12:05:33.073 DEBUG PASSWORD_PREFERENCE Reading gcd_token from preferences
2019-01-07 12:05:33.073 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_PASSWORD
2019-01-07 12:05:33.073 DEBUG PASSWORD_PREFERENCE Reading password from preferences
2019-01-07 12:05:33.880 TRACE CONFIG_ITERATIONS Using 16384 iterations for key derivation
2019-01-07 12:05:34.498 DEBUG STORAGE_NESTING Chunk read levels: [1], write level: 1
2019-01-07 12:05:34.525 INFO CONFIG_INFO Compression level: 100
2019-01-07 12:05:34.526 INFO CONFIG_INFO Average chunk size: 4194304
2019-01-07 12:05:34.526 INFO CONFIG_INFO Maximum chunk size: 16777216
2019-01-07 12:05:34.526 INFO CONFIG_INFO Minimum chunk size: 1048576
2019-01-07 12:05:34.526 INFO CONFIG_INFO Chunk seed: hue
2019-01-07 12:05:34.526 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_PASSWORD
2019-01-07 12:05:34.527 DEBUG PASSWORD_PREFERENCE Reading password from preferences
2019-01-07 12:05:34.527 DEBUG BACKUP_PARAMETERS top: /root/duplicacy-repositories/chat.tbp.land, quick: true, tag:
2019-01-07 12:05:34.527 TRACE SNAPSHOT_DOWNLOAD_LATEST Downloading latest revision for snapshot chat.tbp.land
2019-01-07 12:05:34.527 TRACE SNAPSHOT_LIST_REVISIONS Listing revisions for snapshot chat.tbp.land
2019-01-07 12:05:35.261 INFO BACKUP_START No previous backup found
2019-01-07 12:05:35.262 INFO BACKUP_INDEXING Indexing /root/duplicacy-repositories/chat.tbp.land
2019-01-07 12:05:35.262 DEBUG LIST_ENTRIES Listing
2019-01-07 12:05:35.263 DEBUG INCOMPLETE_LOCATE Failed to locate incomplete snapshot: open /root/duplicacy-repositories/chat.tbp.land/.duplicacy/incomplete: no such file or directory
2019-01-07 12:05:35.263 INFO BACKUP_LIST Listing all chunks
2019-01-07 12:05:35.263 TRACE LIST_FILES Listing chunks/
[...............................................waiting for 1 hour..........................................]
2019-01-07 13:09:58.267 TRACE PACK_START Packing z.exe
2019-01-07 13:09:58.268 INFO BACKUP_THREADS Use 20 uploading threads
2019-01-07 13:09:58.901 INFO PACK_END Packed z.exe (26327201)
2019-01-07 13:10:00.537 DEBUG CHUNK_UPLOAD Chunk 67033008952f94ab4931bb16f5dfa49ce7e76cceb689d77ab0391ac44545ae58 has been uploaded
2019-01-07 13:10:00.537 INFO UPLOAD_PROGRESS Uploaded chunk 2 size 1929475, 942KB/s 00:00:26 7.3%
2019-01-07 13:10:01.725 DEBUG CHUNK_UPLOAD Chunk 997f6590e8072553ba3ddbc27a5425afad5627c712d426bc459d5ad3b0ce6d33 has been uploaded
2019-01-07 13:10:01.726 INFO UPLOAD_PROGRESS Uploaded chunk 3 size 12246480, 4.51MB/s 00:00:03 53.8%
2019-01-07 13:10:01.726 DEBUG CHUNK_UPLOAD Chunk 85b900d5eb6ec8fdd1f040d869b839b57172fa45c4d7ed62742204636063a200 has been uploaded
2019-01-07 13:10:01.730 INFO UPLOAD_PROGRESS Uploaded chunk 1 size 3235212, 5.53MB/s 00:00:02 66.1%
2019-01-07 13:10:01.726 DEBUG CHUNK_UPLOAD Chunk 887469c3e5c66253bdcece8c4b8c4a274ca00973f03e6c7c0c85520fd05b37b6 has been uploaded
2019-01-07 13:10:01.731 INFO UPLOAD_PROGRESS Uploaded chunk 5 size 3675831, 6.70MB/s 00:00:01 80.0%
2019-01-07 13:10:02.030 DEBUG CHUNK_UPLOAD Chunk 4582dde83a9d818e952ea17051475a8d936d2f58483560ec6e4a751dea9eb8d2 has been uploaded
2019-01-07 13:10:02.030 INFO UPLOAD_PROGRESS Uploaded chunk 6 size 2924559, 5.72MB/s 00:00:01 91.2%
2019-01-07 13:10:02.031 DEBUG CHUNK_UPLOAD Chunk acd8795ae1d7214f7b89a8f06138adff320313b08a29521b7badbc2b5477d212 has been uploaded
2019-01-07 13:10:02.031 INFO UPLOAD_PROGRESS Uploaded chunk 4 size 2315644, 6.28MB/s 00:00:01 100.0%
2019-01-07 13:10:02.093 DEBUG CHUNK_CACHE Chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e has been saved to the snapshot cache
2019-01-07 13:10:02.094 DEBUG CHUNK_CACHE Chunk 09277b99e21165a5d240796cf6f5b7e785f482bfdb4a3f25aa51c0c5f78b3532 has been saved to the snapshot cache
2019-01-07 13:10:02.095 DEBUG CHUNK_CACHE Chunk d1ac0118ae56f8a7fc75e7e2dfd6d0df48180e36a7452db8ebfecaa7822699ad has been saved to the snapshot cache
2019-01-07 13:10:03.807 DEBUG CHUNK_UPLOAD Chunk 09277b99e21165a5d240796cf6f5b7e785f482bfdb4a3f25aa51c0c5f78b3532 has been uploaded
2019-01-07 13:10:04.192 DEBUG CHUNK_UPLOAD Chunk d1ac0118ae56f8a7fc75e7e2dfd6d0df48180e36a7452db8ebfecaa7822699ad has been uploaded
2019-01-07 13:10:04.193 DEBUG CHUNK_UPLOAD Chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e has been uploaded
2019-01-07 13:10:04.197 DEBUG UPLOAD_FILE_CACHE Saved file snapshots/chat.tbp.land/1 to the snapshot cache
2019-01-07 13:10:05.615 DEBUG UPLOAD_FILE Uploaded file snapshots/chat.tbp.land/1
2019-01-07 13:10:05.615 INFO UPLOAD_FILE Uploaded z.exe (26327201)
2019-01-07 13:10:05.616 TRACE LIST_FILES Listing snapshots/
2019-01-07 13:10:05.617 TRACE LIST_FILES Listing snapshots/chat.tbp.land/
2019-01-07 13:10:05.618 DEBUG SNAPSHOT_CLEAN Snapshot chat.tbp.land revision 1 needs chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e
2019-01-07 13:10:05.619 TRACE LIST_FILES Listing chunks/
2019-01-07 13:10:05.619 TRACE LIST_FILES Listing chunks/d1/
2019-01-07 13:10:05.619 TRACE LIST_FILES Listing chunks/72/
2019-01-07 13:10:05.620 TRACE LIST_FILES Listing chunks/09/
2019-01-07 13:10:05.620 INFO BACKUP_END Backup for /root/duplicacy-repositories/chat.tbp.land at revision 1 completed
2019-01-07 13:10:05.620 INFO BACKUP_STATS Files: 1 total, 25,710K bytes; 1 new, 25,710K bytes
2019-01-07 13:10:05.620 INFO BACKUP_STATS File chunks: 6 total, 25,710K bytes; 6 new, 25,710K bytes, 10,295K bytes uploaded
2019-01-07 13:10:05.621 INFO BACKUP_STATS Metadata chunks: 3 total, 635 bytes; 3 new, 635 bytes, 1K bytes uploaded
2019-01-07 13:10:05.621 INFO BACKUP_STATS All chunks: 9 total, 25,710K bytes; 9 new, 25,710K bytes, 10,297K bytes uploaded
2019-01-07 13:10:05.621 INFO BACKUP_STATS Total running time: 01:04:31
And here’s the check after that first backup:
Again full debug output
./z.exe -d -log check -tabular
2019-01-07 13:17:45.731 INFO STORAGE_SET Storage set to gcd://backups/duplicacy
2019-01-07 13:17:45.732 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_GCD_TOKEN
2019-01-07 13:17:45.733 DEBUG PASSWORD_PREFERENCE Reading gcd_token from preferences
2019-01-07 13:17:48.406 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_GCD_TOKEN
2019-01-07 13:17:48.406 DEBUG PASSWORD_PREFERENCE Reading gcd_token from preferences
2019-01-07 13:17:48.407 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_PASSWORD
2019-01-07 13:17:48.407 DEBUG PASSWORD_PREFERENCE Reading password from preferences
2019-01-07 13:17:49.400 TRACE CONFIG_ITERATIONS Using 16384 iterations for key derivation
2019-01-07 13:17:49.684 DEBUG STORAGE_NESTING Chunk read levels: [1], write level: 1
2019-01-07 13:17:49.709 INFO CONFIG_INFO Compression level: 100
2019-01-07 13:17:49.710 INFO CONFIG_INFO Average chunk size: 4194304
2019-01-07 13:17:49.710 INFO CONFIG_INFO Maximum chunk size: 16777216
2019-01-07 13:17:49.710 INFO CONFIG_INFO Minimum chunk size: 1048576
2019-01-07 13:17:49.710 INFO CONFIG_INFO Chunk seed: hue
2019-01-07 13:17:49.711 DEBUG PASSWORD_ENV_VAR Reading the environment variable DUPLICACY_PASSWORD
2019-01-07 13:17:49.711 DEBUG PASSWORD_PREFERENCE Reading password from preferences
2019-01-07 13:17:49.711 DEBUG LIST_PARAMETERS id: chat.tbp.land, revisions: [], tag: , showStatistics: false, checkFiles: false, searchFossils: false, resurrect: false
2019-01-07 13:17:49.711 INFO SNAPSHOT_CHECK Listing all chunks
2019-01-07 13:17:49.711 TRACE LIST_FILES Listing chunks/
2019-01-07 13:36:01.154 DEBUG GCD_RETRY [0] Get https://www.googleapis.com/drive/v3/files?alt=json&fields=nextPageToken%2Cfiles%28name%2C+mimeType%2C+id%2C+size%29&pageSize=1000&pageToken=hue&q=%271HdxxmkHiA87dhSUq08VTw3iUqcjK442N%27+in+parents+and+trashed+%3D+false+: unexpected EOF; retrying after 2.92 seconds (backoff: 2, attempts: 1)
2019-01-07 14:02:12.045 TRACE SNAPSHOT_LIST_REVISIONS Listing revisions for snapshot chat.tbp.land
2019-01-07 14:02:12.822 DEBUG DOWNLOAD_FILE_CACHE Loaded file snapshots/chat.tbp.land/1 from the snapshot cache
2019-01-07 14:02:12.824 INFO SNAPSHOT_CHECK 1 snapshots and 1 revisions
2019-01-07 14:02:12.846 INFO SNAPSHOT_CHECK Total chunk size is 2439G in 522249 chunks
2019-01-07 14:02:12.850 DEBUG CHUNK_CACHE Chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e has been loaded from the snapshot cache
2019-01-07 14:02:12.851 INFO SNAPSHOT_CHECK All chunks referenced by snapshot chat.tbp.land at revision 1 exist
2019-01-07 14:02:12.852 DEBUG DOWNLOAD_FETCH Fetching chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e
2019-01-07 14:02:12.852 DEBUG CHUNK_CACHE Chunk 723ba6b35f29ad2b2fc4014c1bc504d416173653fef149ccb6d5041976fcb05e has been loaded from the snapshot cache
2019-01-07 14:02:12.853 INFO SNAPSHOT_CHECK
chat.tbp.land | 1 | @ 2019-01-07 12:05 -hash | 1 | 25,710K | 9 | 10,297K | 9 | 10,297K | 9 | 10,297K |
chat.tbp.land | all | | | | 9 | 10,297K | 9 | 10,297K | | |
