Possible password obfuscation in Web-UI log
Greetings!
I’m an avid user of the RSA feature of Duplicacy and have yet to find any other software who can match it.
One very minor inconvenience I’m running into (and might be a security issue if you miss it) is that if you use the Web-UI to restore files (and add -key and -key-passphrase) to the command line arguments, the clear-text password will end up in the duplicacy_web.log
While I can certainly delete this file after each restore, perhaps an obfuscation of the password written to the log would be an improvement worth considering?
Thanks for your consideration,
Alex
