I had an issue and had to do a restore which I did with duplicacy web gui and it worked fine as I had another backup of the web config file. I had a backup from another software I don’t care for and neighther of these seem to contain the cli .duplicacy directory. I have a fully functional web gui, I was wondering if I could rebuild the cli preferences file somehow based on information in the webgui configuration files. The file formats are rather different.
You can find those preferences file under ~/.duplicacy-web/repositories/localhost/*/.duplicacy.
Thank you very much! Is there a way to copy the storage password over? I put it inside key brackets as password copying from the web config. I get an message authentication failed.
