I’m just wondering if there is a method to retrieve the password used for encrypted storage?
I am running Duplicacy in unraid (docker essentially). I’ve had an issue where I’ve needed to re-add the storage on one of my less critical buckets, but I couldn’t do it without the password. I wasn’t sure of what the password was, and what I had documented was incorrect apparently.
So now I need to confirm I know the password for the critical storage buckets, so if the need arises that I need to add the storage from a clean slate (say critical hardware failure etc) and restore the data from the backups.
Is there a method to test/confirm the password used for the password protection placed on backups? Or should I create new critical buckets and ensure that documentation is completed properly
