hi, the power to my house yesterday when i was doing the first upload of a large folder (35gb) to backblaze b2.
i have just started the backup job again and will leave it running until it is finished.
1 have two questions,
1.is there any way to verify that the files in bbb2 match those in my local folder and if there are corrupted?
2. once the 25gb upploads, any new files that i add to that folder will be added incrementally to the bbb2 folder, correct?
thank you
also i am using unraid, does anyone have a very simple guide to using telegram with duplicacy, i have looked at the guide listed in this forum but to be honest, i dont understand it, thank you…
