Hello
Is there a way to lock the configuration (with a password for instance) so that users don’t change things?
Will there be a way to get a centralized account management?
Thanks
David
Hello
Thanks
David
Currently it is not supported, but what about a registry key (or a user defaults key on macOS) to lock the GUI such that no changes can be made? Would that work for you?
The centralized management system is in our plan but it may take a while.
