Private key always result to error: sequence truncated
I am using the document’s command to generate my private and public key
 openssl genrsa -aes256 -out private.pem 2048
 openssl rsa -in private.pem --outform PEM -pubout -out public.pem
because my OpenSSL version is:
OpenSSL 3.0.2 15 Mar 2022 (Library: OpenSSL 3.0.2 15 Mar 2022)
It will always generate pkcs8 format of private key:
-----BEGIN ENCRYPTED PRIVATE KEY-----
MII...
-----END ENCRYPTED PRIVATE KEY-----
So I have to convert it to pkcs1 using this command:
openssl pkey -in private.pem -traditional > private_pkcs1.pem
-----BEGIN RSA PRIVATE KEY-----
MII...
-----END RSA PRIVATE KEY-----
But using this key always result to this error when I execute:
duplicacy_linux_x64_3.1.0 -d check -key /path/to/my/private_pkcs1.pem -files
error:
asn1: syntax error: sequence truncated
What’s the right command for generate the key for OpenSSL 3.x? Thanks for any advice.
This worked for me:
openssl genrsa -aes256 -out private.pem -traditional 2048
Thank you very much, that did the trick.
