Problem adding Wasabi EU in cli
I’m trying different cloud providers before deciding which one to use but I can’t get Wasabi Europe to work.
I got a trial account in eu-central, I made a bucket (lets pretend it is my-bucket) and I created a new access key.
I used this command to add:
duplicacy add -e wasabi_data asterix_home s3://s3.eu-central-1.wasabisys.com/my-bucket/duplicacy
I’m asked for:
Enter S3 Access Key ID: (entered my generated key id)
Enter S3 Secret Access Key: (entered my generated access key)
Enter storage password for s3://s3.eu-central-1.wasabisys.com/my-bucket/duplicacy: (made up my own password)
Then I get this:
Failed to download the configuration file from the storage: MissingRegion: could not find region configuration
What am I doing wrong?
Best regards
Nicke
Maybe one of these works:
wasabi://s3.eu-central-1.wasabisys.com/the/path
or
 wasabi://eu-central-1@s3.eu-central-1.wasabisys.com/the/path
Thanks @TheBestPessimist!
wasabi://eu-central-1@s3.eu-central-1.wasabisys.com/the/path works as well as
s3://eu-central-1@s3.eu-central-1.wasabisys.com/the/path
Is there a difference? I want to sure that duplicacy is using the wasabi module and not the S3.
Wasabi is nominally compatible with AWS S3, but the copy-and-delete
method used for renaming objects creates additional expense under
Wasabi’s billing system. This module is a pass-through to the
existing S3 module for everything other than that one operation.
They will both work, but you should use the wasabi:// one to take advantage of Wasabi’s special rename API to reduce storage costs.
