I just tried the web gui. It now offers support for https, and the docs say it would even get a cert via let’s encrypt.
Problems I encountered (and could not solve):
- It’s not clear what to input into the gui’s fields for HTTPS address and HTTPS domain. The fields suggest to put just a port number (prefixed with “:”) into the first field, but is that really correct?
- Bug: When I enter anything, even just changing the HTTP address and then click Save, the service says to restart, but then shows the OLD values again after a refresh. I found that I had to actually stop and relaunch the gui manually to make the changes work. Background: I am on Debian 10, and launched the gui manually from the cmdline. It’s not clear how the program wants to relaunch itself in this case - maybe it expects to run as a service under a specific name? But the quick install instructions do not mention anything about setting this up, or do they?
- Assuming my server’s IP is 22.33.44.55, and the A record for it named “my.domain.com”: When I enter “22.33.44.55:3877” into “HTTPS address” and “my.domain.com” into “HTTPS domain” and then relaunch the gui, it never starts up. Using the “-print-credentials” I see only:
Log directory set to /root/.duplicacy-web/logs
Duplicacy Web Edition 1.1.0 (818F2B) - Could it be that it wants to register with Let’s encrypt but doesn’t succeed? If it does, I need to see some progress about it. Also some docs that tell me what protocol it wants to use, or how I can supply the certs manally, because I wonder if it fails because my firewall blocks the verification process (which requires an open port for that).
