I currently have 4 repositories on my NAS that all back up to B2. The NAS is an i3 with 4 GB RAM, running a linux variant. The repos are as follows, with approximate info from duplicacy check -tabular. There are about 150-175 revisions in each repo (they all run nightly).
- files: 5,900 chunks, 7 GB
- music: 424,000 chunks, 522 GB
- videos: 19,000 chunks, 22 GB
- photos: 1,300,000 chunks, 1,500 GB
Thus far I have not run prune at all; I didn’t get around to setting up the scripts/scheduling of it before, and I am attempting to do so now. Since I am just getting prune set up, I am running it with -dry-run, but 3 times in a row, my system has full on crashed, and my guess is that duplicacy consumes all the available RAM (the process shows to be using 1.6 GB, 90+% memory utilized) and it just runs out of resources. Under normal load the system’s memory is about 20-30% utilized.
Here is the command that I am running:
duplicacy -log -verbose -debug prune -dry-run -all -storage b2 -keep 0:360 -keep 30:180 -keep 7:30 -keep 1:7
and here are the last 4 lines from the log file (most of the entries are DOWNLOAD_FETCH and CHUNK_CACHE):
2018-07-22 20:02:36.722 DEBUG DOWNLOAD_FETCH Fetching chunk 9e606c48570d5dc71309c3ef155872cf504461ece423993baa68a49a95f74031
2018-07-22 20:02:37.829 DEBUG CHUNK_CACHE Chunk 9e606c48570d5dc71309c3ef155872cf504461ece423993baa68a49a95f74031 has been loaded from the snapshot cache
2018-07-22 20:02:37.832 DEBUG DOWNLOAD_FETCH Fetching chunk 1ec49414357d5ec7a4e09d161c2fa595959fc2520ea8cc5177fde75a8c5b5291
2018-07-22 20:02:39.985 DEBUG CHUNK_CACHE Chunk 1ec49414357d5ec7a4e09d161c2fa595959fc2520ea8cc5177fde75a8c5b5291 has been loaded from the snapshot cache
So, before I start digging through system logs or buying more RAM (I’d probably add another 8 GB for 12 total), I just want to ask: for a backup of this size, does 4 GB of memory seem reasonable, or could there be an issue with how dry run is implemented (which consumes more memory since it isn’t saving/writing anything), and if so, should I just do the prune for real (would it be as intensive)? Should I try breaking it up to only do one repo at a time (using the -id <snapshot id> param, if I understand it correctly? If it is normal to consume that much memory for a prune, is it only because I haven’t done one yet against this storage, and if I get it completed, subsequent runs of prune will take less, or should that usage be expected for each run? I can run it manually from a computer with more memory as a test as well. Is there any other info that would be helpful?
