Prune - FOSSIL_RESURRECT - Chunk already exists
would like to ask for your support about the following:
My schedule is this “Backup/Check/Prune/Check”. For the first time i received the following in the Prune log:
Options: [-log prune -storage hidden -a -threads 10 -keep 0:7]
2021-11-17 01:01:33.066 INFO STORAGE_SET Storage set to hidden
2021-11-17 01:01:34.128 INFO BACKBLAZE_URL download URL is: https://f003.backblazeb2.com
2021-11-17 01:01:35.498 INFO RETENTION_POLICY Keep no snapshots older than 7 days
2021-11-17 01:01:39.168 INFO FOSSIL_COLLECT Fossil collection 18 found
2021-11-17 01:01:39.168 INFO FOSSIL_DELETABLE Fossils from collection 18 is eligible for deletion
2021-11-17 01:01:39.168 INFO PRUNE_NEWSNAPSHOT Snapshot AppData revision 225 was created after collection 18
2021-11-17 01:01:39.193 INFO PRUNE_NEWSNAPSHOT Snapshot DockerCompose revision 230 was created after collection 18
2021-11-17 01:01:39.195 INFO SNAPSHOT_DELETE Deleting snapshot AppData at revision 218
2021-11-17 01:01:39.213 INFO SNAPSHOT_DELETE Deleting snapshot DockerCompose at revision 223
2021-11-17 01:01:39.696 INFO CHUNK_DELETE The chunk fa2841323a4c5206845b2a65d35c371151c55f8720e2a45edcf587dc8bb18d32 has been permanently removed
2021-11-17 01:01:40.061 INFO CHUNK_DELETE The chunk c02d7089260ad42a6dee1c235ed4e2070e0fa6c6e6249ba3291a673c00020963 has been permanently removed
2021-11-17 01:01:40.096 INFO CHUNK_DELETE The chunk 8be66d61618dea3350207b94476234d8f884ddbac920abd6638415bc087d09ff has been permanently removed
2021-11-17 01:01:40.119 INFO CHUNK_DELETE The chunk 7c6b2664c16120cc047bb8710c258da0bd0a0872fe2acf0b79e45bca00532192 has been permanently removed
2021-11-17 01:01:40.123 INFO CHUNK_DELETE The chunk 2cf3f693532d2859153506f79c34ef3adfe46e14c9d73e2a449b06f53707790f has been permanently removed
2021-11-17 01:01:40.176 INFO CHUNK_DELETE The chunk a5ab38cce5941287f293ad307254773a9d0012dad4469c9a07a8421c8175b059 has been permanently removed
2021-11-17 01:01:40.265 INFO CHUNK_DELETE The chunk 945a9a6d07cec80311e532edb2ad2679a7fd1708f7de1f384a4a66dcbd0c8ff1 has been permanently removed
2021-11-17 01:01:40.355 INFO CHUNK_DELETE The chunk 281270e04371ac7b1fb27f6b07ac952ec82b814154b5f7cf06c01e5bdb07e7cd has been permanently removed
2021-11-17 01:01:40.472 INFO CHUNK_DELETE The chunk 0ceba740f984157979a0ac8778765e9c5b4eda5565029db7f580b27fa64e9c87 has been permanently removed
2021-11-17 01:01:40.515 INFO CHUNK_DELETE The chunk c20a162c9f647c92791da4381dc1b5d92dac1eb8dc832c36e698d7a08f78b1e4 has been permanently removed
2021-11-17 01:01:40.716 INFO CHUNK_DELETE The chunk 5a967aae4b444350c0018dc7549e0b200d93357a2a3c2c491320a1e2f3c7a21e has been permanently removed
2021-11-17 01:01:40.745 INFO FOSSIL_RESURRECT The chunk 65d2e7f18a74ca70b787c00b7d5c1d66a35f60156dded0e59861424b48a01ca4 already exists
2021-11-17 01:01:40.749 INFO CHUNK_DELETE The chunk abd8765c9f6d0684e66f2a13e73e179e1dbcf830965d9803954a3b8a93fc6853 has been permanently removed
2021-11-17 01:01:40.872 INFO CHUNK_DELETE The chunk 4c66cf2a08b5ffa5bc99b7f174a5b48c2f9fdaff308b23bf0eef585edf5ffaa7 has been permanently removed
2021-11-17 01:01:41.051 INFO CHUNK_DELETE The chunk 342b66601b8b3603bb58ab973c84c2ce685cb67908e465268227bc9b440c288f has been permanently removed
2021-11-17 01:01:41.130 INFO CHUNK_DELETE The chunk b64d1874453e0c28f34d1d1abc17ba64bf2a22771871ba36d9ea84a90c83c955 has been permanently removed
2021-11-17 01:01:41.830 INFO CHUNK_DELETE The chunk 51bfa713580babad00ba0c58f2722a9444dcfb5c5867ad7084a9c83ac9351a11 has been permanently removed
2021-11-17 01:01:54.611 INFO FOSSIL_COLLECT Fossil collection 19 saved
2021-11-17 01:01:55.174 INFO SNAPSHOT_DELETE The snapshot DockerCompose at revision 223 has been removed
2021-11-17 01:01:55.552 INFO SNAPSHOT_DELETE The snapshot AppData at revision 218 has been removed
What means that a fossil already exists during the prune activity?
Thanks in advance!
That means when a fossil is turned back into a chunk (by renaming) the chunk with the same name already exists. This can happen if a new backup uploads the same chunk again so it is completely normal.
Thanks for your reply but I still can’t understand this process. Why the resurrect of a chunk during the prune and not during the backup?
Also why it was trying to resurrect a chunk in the first place, and then find that a chunk with the same name already exist?
It would be too much overhead for the backup to check if the fossil exists before uploading every new chunk.
This can happen when, say, a backup to be deleted contains an old version of a file, but later you revert that file to the old version and run the backup while the prune command is running. Your case may vary but this FOSSIL_RESURRECT message is the proof that the Two-Step Fossil Collection works and that you can simply delete every chunk not referenced by existing backups since some of them may be needed by a backup still in progress (which is unknown to the prune command).
