I was reading the prune command and I understood that if you use-id and -storage option, that you could go to a 2nd PC to any folder and then you could prune the -id and -storage from the 1st PC, assuming this is online storage. When I tried it, I received a message that the repository has not been initiated.
On the 2nd PC I was hoping to be able to initiate a prune command, as pruning can take longer than the backup. Is this possible?
