I have a large binary volume file that was supposed to be filtered out, but I accidentally backed up a good 100GB of it with the cli. I killed the process, fixed the filter and started again.
Will these unwanted chunks still be part of a revision or will they be unreferenced? If they are part of the revision, will that be the same revision I am continuing now? Can I prune exhaustive to delete these unwanted chunks (unreferenced)? Should I prune before completing this revision?
edit: I am syncing for the first time on a new PC, but the repository is mostly the same as before and the old PC is gone. It seems that I should just prune exhaustive and start over on this machine. Does that seems like a good idea?
