Running prune -keep 1:1 on snapshot with multiple revisions during the day keeps the oldest revision. Loses all changes between oldest and youngest revisions.
This may happen with other -keep options. I have only seen it with -keep 1:1.
Would expect it to keep the youngest revision to preserve the changes that occurred during the day.
Hourly backup, prune and check (in that order). Got 24 revisions for the day.
I would expect revision 32 to have been kept as it encompasses all changes for that day. Instead revision 12 was kept.
11:00 pm:
2019-09-07 23:00:24.992 INFO SNAPSHOT_CHECK
test-snap | 12 | @ 2019-09-07 00:00 | 6609 | 28,670M | 5723 | 27,532M | 3 | 1,692K | 70 | 223,587K |
test-snap | 13 | @ 2019-09-07 01:00 | 6612 | 28,670M | 5724 | 27,532M | 3 | 1,692K | 4 | 1,738K |
test-snap | 14 | @ 2019-09-07 02:00 | 6615 | 28,670M | 5725 | 27,532M | 3 | 1,693K | 4 | 1,739K |
test-snap | 15 | @ 2019-09-07 03:00 | 6618 | 28,670M | 5726 | 27,532M | 3 | 1,693K | 4 | 1,739K |
test-snap | 16 | @ 2019-09-07 04:00 | 6621 | 28,670M | 5727 | 27,532M | 3 | 1,693K | 4 | 1,740K |
test-snap | 17 | @ 2019-09-07 05:00 | 6624 | 28,670M | 5728 | 27,532M | 3 | 1,694K | 4 | 1,741K |
test-snap | 18 | @ 2019-09-07 06:00 | 6627 | 28,670M | 5729 | 27,532M | 3 | 1,694K | 4 | 1,741K |
test-snap | 19 | @ 2019-09-07 07:00 | 6630 | 28,670M | 5730 | 27,532M | 3 | 1,694K | 4 | 1,742K |
test-snap | 20 | @ 2019-09-07 08:00 | 6633 | 28,670M | 5731 | 27,532M | 3 | 1,695K | 4 | 1,743K |
test-snap | 21 | @ 2019-09-07 09:00 | 6640 | 28,670M | 5732 | 27,532M | 3 | 1,695K | 4 | 1,752K |
test-snap | 22 | @ 2019-09-07 10:00 | 6645 | 28,670M | 5732 | 27,532M | 3 | 1,696K | 5 | 2,422K |
test-snap | 23 | @ 2019-09-07 11:00 | 6648 | 28,670M | 5733 | 27,532M | 3 | 1,696K | 4 | 1,748K |
test-snap | 24 | @ 2019-09-07 12:00 | 6651 | 28,670M | 5734 | 27,532M | 3 | 1,696K | 5 | 2,415K |
test-snap | 25 | @ 2019-09-07 13:00 | 6654 | 28,670M | 5735 | 27,533M | 3 | 1,697K | 4 | 1,749K |
test-snap | 26 | @ 2019-09-07 14:00 | 6657 | 28,671M | 5736 | 27,533M | 3 | 1,697K | 4 | 1,750K |
test-snap | 27 | @ 2019-09-07 15:00 | 6659 | 28,675M | 5740 | 27,536M | 4 | 1,994K | 35 | 87,382K |
test-snap | 28 | @ 2019-09-07 18:00 | 6671 | 28,675M | 5740 | 27,536M | 3 | 1,995K | 4 | 2,100K |
test-snap | 29 | @ 2019-09-07 19:00 | 6674 | 28,675M | 5741 | 27,536M | 3 | 1,995K | 4 | 2,054K |
test-snap | 30 | @ 2019-09-07 21:00 | 6680 | 28,675M | 5742 | 27,537M | 3 | 1,996K | 5 | 2,429K |
test-snap | 31 | @ 2019-09-07 22:00 | 6683 | 28,675M | 5743 | 27,537M | 3 | 1,996K | 4 | 2,057K |
test-snap | 32 | @ 2019-09-07 23:00 | 6686 | 28,675M | 5744 | 27,537M | 5 | 2,427K | 5 | 2,427K |
Midnight:
2019-09-08 00:00:25.850 INFO SNAPSHOT_CHECK
test-snap | 12 | @ 2019-09-07 00:00 | 6609 | 28,670M | 5723 | 27,532M | 5 | 2,304K | 70 | 223,587K |
Prune:
Options: [-log prune -storage test -keep 7:30 -keep 1:1 -a]
2019-09-08 00:00:07.404 INFO STORAGE_SET Storage set to /path/to/storage
2019-09-08 00:00:08.415 INFO RETENTION_POLICY Keep 1 snapshot every 7 day(s) if older than 30 day(s)
2019-09-08 00:00:08.415 INFO RETENTION_POLICY Keep 1 snapshot every 1 day(s) if older than 1 day(s)
2019-09-08 00:00:08.969 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 13
2019-09-08 00:00:09.009 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 14
2019-09-08 00:00:09.039 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 15
2019-09-08 00:00:09.068 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 16
2019-09-08 00:00:09.100 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 17
2019-09-08 00:00:09.126 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 18
2019-09-08 00:00:09.155 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 19
2019-09-08 00:00:09.183 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 20
2019-09-08 00:00:09.212 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 21
2019-09-08 00:00:09.245 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 22
2019-09-08 00:00:09.273 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 23
2019-09-08 00:00:09.300 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 24
2019-09-08 00:00:09.328 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 25
2019-09-08 00:00:09.355 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 26
2019-09-08 00:00:09.384 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 27
2019-09-08 00:00:09.414 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 28
2019-09-08 00:00:09.444 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 29
2019-09-08 00:00:09.474 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 30
2019-09-08 00:00:09.505 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 31
2019-09-08 00:00:09.532 INFO SNAPSHOT_DELETE Deleting snapshot test-snap at revision 32
was supposed to save the first revision of the day, and delete the rest from that day. That’s what i expect at least, and this seems to be what
