today I have noticed that if i have to do a restore from the latest revision (27) I only see one folder, if I use revision 26 can see more folders.
I use the following prune parameters: -keep 0:360 -keep 7:30 -keep 1:7 -keep 1:1 -a.
And this backup parameter: -threads 4
Is this the normal behavior?
And I have noticed that when I start the backup, Duplicacy takes as long as it would take to completely back up everything again.
Here are the latest backup, check and rune logs:
Thx for your help.
