Question about bit-identical third-party copy & maintaining storage onwards
I have tried to search the forums for an answer to this specific question, but I am still unsure:
If I copy my current up to date repository from dest1 to dest2 with rclone
Then I initialize dest2 with web GUI.
And now I want to continue onwards backing up to both dest1 & dest2 in parallel.
Are these 2 storages bit-identical and onwards into the future if I keep backing up to both of them?
Or do I need to add some kind of config parameter manually to dest2 to ensure that it’s bit-identical to dest1 into the future?
Yes. Passing But-identical results in some data from the config file being copied from source storage: duplicacy/src/duplicacy_config.go at 065ae50868574404c502fb8b9508a2475d218337 · gilbertchen/duplicacy · GitHub
You copied the whole config file.
