Question about restore (How work it)
I backup a volume folder:
/volumes
  • …/volume1
  • …/volume2
  • …/volume3
Backups are generated every day at 00:00hs. I use the web GUI. If I want to rollback to the volume2 folder to the last backup, what attributes do I have to set so that it can delete and restore the changes to the files without having to delete the current volume2 folder and restore the whole folder again?
I don’t really know how the restore command works because I always delete the folder and restore it using restore but I don’t know if this works like this.
Sorry if this is a dumb question. I’m still new to this.
Here is a quick start: Duplicacy User Guide and here are additional options you can use to control the behavior restore · gilbertchen/duplicacy Wiki · GitHub
