Question on VSS Issue
I am using the gui on Windows 8.
If I run the backup with outlook closed- everything works fine.
If I run the backup with outlook opened I get the following dialog pop up
error: failed to read 0 bytes: read c:\users\owner\rep.duplicacy\shadow\users\owner…\appdata\Local\Microsoft\Outlook\kv@mail.com.ost: the process cannot access the file because another process has locked a portion of the file.
I am running duplicacy as a service and have Enable Volume Shadow Copy checked.
Any ideas?
Thanks!!!
Can you run the GUI version with elevated privileges and VSS enabled? And then check Windows Event Viewer to see if there any event log related to this error.
Well, I saw some VSS related errors in the event log and I decided to solve my problem by forcing outlook to close before my backup.
I used the pre-backup script option for this and TASKKILL /IM outlook.exe
For this user- that will be fine and probably the most reliable.
Thanks.
