Hey There!
New user, just doing some initial testing and working on failure scenarios now.
I’m running duplicacy as a docker container, backing up to the docker host then copying the data to b2. This is working great.
I’ve just now deleted the appdata folder for the container and rebooted it to start with a fresh un-configed container. I can manually add my b2 and local storage dests and it see the originally backup IDs “plex” and “unifi-controller” but there doesn’t seem to be any way to recover the actual configuration of those jobs, ie the paths to the files i want to backup.
am i missing something here or is that info not stored in the backup itself? Obviously backing up all the duplicacy json files would be ideal, but I’m targeting a worst case scenario, plus I’d need a second backup solution to accomplish that.
