Rename default storage?
I want to rename the default storage to something else. Would I just have to edit .duplicacy/preferences and rename .duplicacy/cache/default to .duplicacy/cache/newname or is there more to it than that?
I guess in a similar vein, if I want to remove a storage, do I just have to remove it from preferences and remove the directory for the storage under .duplicacy/cache?
That should do it. I’ve tested it but I don’t think there would be any problem by just looking at the code.
Edit: I’ve tested it -> I haven’t tested it but…
