If I want to rename a snapshot id, is it as simple as changing the folder name in the storage “snapshots” folder, and updating the “id” in the preferences json file?
Thanks,
-Alex
Thanks,
-Alex
Yep.
Eventually also delete from local cache.
Thanks, just wanted to make sure I don’t mess something up!
Actually no, i think i am wrong! I don’t think it’s that simple if you are encrypted. I think there is an issue on GitHub (or here in the forum) about renaming. Please check those first!
Noted, I’ll use a small test repository first, thanks.
@TheBestPessimist is right. If the storage is encrypted then you can’t simply rename the snapshot folder.
I guess this problem still exsits. So it is not possible to rename Snapshots when encryption is used.
Which tasks do I have to execute to create a new snapshot id based on the old one without the need to reupload everything?
You don’t have to re-upload everything - the chunk data can be de-duplicated even if you started future backups with a fresh snapshot ID. Those snapshot files are basically just the metadata.
thanks for this tip
basically I can create a new snapshot id on the same storage witht he same source files and after that one I can delete the old snapshot?
Yep, exactly that - and as a final clean-up, you could run a Prune operation with the -exhaustive flag to get rid of any unreferenced chunks (there might be a handful).
Is there a git ticket for renaming a snapshot within an encrypted storage?
