Scenario:
Two storages, one local and one cloud.
The cloud storage is copy compatible with the local storage so i can replicate from local to cloud using the copy command.
Issue:
I need to replace the local storage and I want to copy the backups from the current local storage to the new local storage. So my thought was to make the new local storage copy compatible with the old local storage and then run the copy command. However, if I was to do this the cloud storage would not be copy compatible with the new local storage and therefore I could not use the copy command.
Has anyone got a resolution for this or am I understanding things incorrectly?
