I’ve opened a dos prompt and did this:
SET TOOL_DIR=D:\Tools\@Command Line Tools\duplicacy_x64
SET TOOL_EXE=%TOOL_DIR%\duplicacy.exe
SET PREF_DIR=%TOOL_DIR%\!preferences
SET EXCLUDES=%TOOL_DIR%\exclusions.txt
SET ID=Tools
SET SRC=D:\Tools
SET DST=E:\duplicacy_tst_tools
"%TOOL_EXE%" init -c 16M -min 4M -max 64M -pref-dir "%PREF_DIR%\%ID%" -repository "%SRC%" "%ID%" "%DST%"
"%TOOL_EXE%" set -filters "%EXCLUDES%"
"%TOOL_EXE%" backup
Everthing went smoothly.
I closed that dos prompt window and opened a new one.
I’ve used the same SET … commands (but no init or -set this time) and after that
"%TOOL_EXE%" backup
But now I get a
Repository has not been initialized
How to I tell duplicacy to pickup the right preferences file so that it doesn’t fail?
Is there no other way then CD’ing into the %TOOL_DIR% folder before executing the backup?
