Restore and folder structure with pattern
I’m doing some testing, and when I restore a full repository to a new empty folder, the folder structure is rebuilt correctly.
But when I do the restore using a include/exclude pattern option (to restore only a subset of files), the files are recovered to the root folder of the restore folder.
I’m using a command similar to this:
duplicacy restore -ignore-owner -stats -r 1 -storage dropbox://COMP_Admin_test
Sorry I didn’t response earlier. I saw you closed the github issue. Did it work as expected?
Hello Gilbert, thanks for the reply.
In the end I discovered that it was a small error of “” and “/” in the filtering criteria.
P.S.: The correct would be to exclude the issue of github, but (as far as I know) it is not possible …
