Hello, I’m running a test restore and am having difficulty with the -delete flag through the Web-UI. I am not running any other flags other than -delete, and have chosen the root directory. It is restoring to the same repository that the backup was made from, so I am not restoring to an alternate location.
I placed a test screenshot png file into one of the subdirectories, and would expect it to be deleted since it is not in the snapshot, and yet, it is not deleted. However, the logs have this, and seem to indicate that “2021-10-04 11:33:15.008 INFO RESTORE_DELETE Deleted Music Library/folder_1/Screen Shot 2021-10-03 at 10.54.38 AM.png” has been deleted. Any ideas?
Excerpt from the logs are below. Thank you!
2021-10-04 11:33:13.190 INFO RESTORE_START Restoring /Volumes/music to revision 1
2021-10-04 11:33:15.000 INFO DOWNLOAD_PROGRESS Downloaded chunk 1 size 2965876, 1.41MB/s 00:00:01 100.0%
2021-10-04 11:33:15.009 INFO RESTORE_DELETE Deleted Music Library/folder_1/.smbdeleteAAA12b
2021-10-04 11:33:15.010 INFO RESTORE_DELETE Deleted Music Library/folder_1/.smbdeleteAAA129
2021-10-04 11:33:15.028 INFO DOWNLOAD_DONE Downloaded .DS_Store (10244)
2021-10-04 11:33:15.028 INFO RESTORE_END Restored /Volumes/music to revision 1
2021-10-04 11:33:15.028 INFO RESTORE_STATS Files: 1 total, 10K bytes
