Restore exits/fails when file has gid system
Restoring a directory which has a file with gid system. This is on macOS.
Either a) the file should be restored correctly, b) the file should be restored but without gid set, or c) if it must throw an error, for the restore to continue.
  1. This error in the log:
    2020-09-21 18:16:18.840 ERROR RESTORE_CHOWN Failed to change uid or gid: lchown : operation not permitted
  2. The restore terminates without restoring further files.
You can either run restore -ignore-owner ... to ignore uid/gid or sudo restore ... to have the permission to set uid/gid.
Would the sudo part work if I run the container as privileged?
Yes, I think so…
It didn’t, at least for me
So, what do I do on the WEB version to solve this?
Failed to change uid or gid: lchown /home/lance/restored/.duplicacy-web/logs/backup-20221104-000001.log: operation not permitted
Exit code: 100
one solution is to add ‘-ignore-owner’ to the options section in restore (GUI)
This is a bit frustrating. I used duplicacy to backup some docker containers and restored with -ignore-owner because even with duplicacy elevated in the shell it fails to restore without that flag. Now the containers perms are all messed up. I think I’ll be able to fix manually but still kinda a pain.
I encountered this issue and i got away with it but adding -ignore-owner in the restore options however i agreed that it is not very elegant. Is there a more automatic way of doing it with out adding the command line to the option every time?
