Restore Failed to create the file for in-place writing
duplicacy restore -r 19
OR
duplicacy restore -r 19 -overwrite
to different, empty folder on NTFS-format network drive. Backup was created using x86_64 QNAP qpkg; restore done with duplicacy_win_x64_2.7.1.exe.
Expect all files in revision 19 to be restored.
Failed to create the file \?\X:\Restored_Repositories\Public\Downloads\Topaz Labs\Topaz Plugins Photoshop Utility 1.3.3.bat__MACOSX._Topaz Plugins Photoshop Utility 1.3.3.bat for in-place writing
The failing filename begins with “.”, indicating a hidden file on Linux, though the Hidden DOSATTRIB is not set. Unlike https://forum.duplicacy.com/t/duplicacy-restore-with-read-only-files-on-windows-failed-to-open-for-in-place-writing/1464?u=gorlen, the file does not already exist before the restore.
restore failed to create file for in-place writing.txt (2.3 KB)
