Restore from different machine
If i want to restore the data from a different machine, what is the workflow? I’m not sure i can see the instructions in the guide, or have missed them at least.
thanks.
Just use the same storage on the second machine, and then switch to the Restore tab and select the repository id associated with the first machine. You’ll then be able to list revisions as if you were still on your first machine and restore files as needed.
Please refer to the Restore section in the User Guide for restore instructions.
