I must have used duplicacy over 2 years now to backup my files, but now trying a restore it fails…
Sounds like files from the Remote Location cannot be located. Maybe they have been Deleted by mistake?
You should run a Check on them.
Could you post the relevant section of the log file or the exact error text you’re getting?
I simply deleted the old UI and installed the web version. Moving was easy and a restore works now, although slowish, 2mb/s.
Don’t forget to use threads!
