Hello,
when restoring from Web Edition the file permissions will be mantained? How can i avoid that the permission are mantained?
I just need to add " -ignore-owner" in the Options field of the restore tab in the Web Edition?
Hello,
The -ignore-owner option will disable setting the uid/gid of each restored file. There is no option to disable setting the permissions.
You just need to run the web GUI as root/administrator if you’re getting restore errors caused by not being able to change the permissions.
Uh ok, let’s see if i understood.
So by default i will restore files keeping their original uid/gid. Correct?
About permissions, they are always kept but there is no option to disable this, right?
Thanks again!
Both are correct…
Thank you
