Restore -persist should ignore errors from symlink creation
I’m trying to restore something using -persist as i expected all errors to be swallowed.
It seems errors related to symlink creation are not ignored:
PS C:\duplicacy-repositories\restore> .\.duplicacy\z.exe restore -r 791 -persist
Storage set to G:\My Drive\backups\duplicacy
Parsing filter file \\?\C:\duplicacy-repositories\restore\.duplicacy\filters
Restoring C:\duplicacy-repositories\restore to revision 791
Can't create symlink C__Users_link/All Users: symlink C:\ProgramData \\?\C:\duplicacy-repositories\restore\C__Users_link\All Users: A required privilege is not held by the client.
I believe -persist is meant to skip all errors. It only skips errors that cannot be easily fixed, such as download errors caused by corrupted chunks. If there is other way to fix the error like in this case giving the command sufficient permission then there is really not necessary to skip this kind of errors.
Do you mean “is not meant”?
I don’t know if I agree with your opinion here.
I am also having this issue. But unlike @TheBestPessimist it is not a permission issue and there is no way around it other than using a filter to exclude the relevant folder. Using -persist, -ignore-owner or -overwrite doesn’t make a difference.
Perhaps it would be better if Duplicacy continued the restore process and summarized these errors after completion instead of stopping the entire process?
duplicacy restore -storage "SOME_STORAGE_NAME" -r 24
Storage set to Q:\SOME_PATH
Indexing C:\Users\admin\Desktop\restore
Parsing filter file \\?\C:\Users\admin\Desktop\restore\.duplicacy\filters
Can't create symlink Backblaze_Personal_Backup/wine/dosdevices/c:: symlink ..\drive_c \\?\C:\Users\admin\Desktop\restore\Backblaze_Personal_Backup\wine\dosdevices\c:: The filename, directory name, or volume label syntax is incorrect.
