I have an external drive formatted with zfs. Used storage is about 1.45 TB. I’m doing some test restores and it’s taking quite a long time.
I am trying to restore a pdf and it’s been almost an hour. After a while I find it takes too long so I stop it, so I don’t know how long it would actually take. I tried restoring through both the GUI and the beta web tool. I haven’t tried the CLI.
On the web tool it says “starting” and that’s all I see. I did some other test restores on other repositories, and those restores were a lot quicker. Though their storage size were smaller (about 300 GB on one and 4 GB on another). Is there any way I can speed it up? Latest version of duplicacy GUI on mac os x.
This is from the log file, not sure if it is of any use
2018-12-03 22:53:38.526 INFO REPOSITORY_SET Repository set to /Volumes/pool
2018-12-03 22:53:38.526 INFO STORAGE_SET Storage set to /Volumes/Pool Backup/Local Backup
2018-12-03 22:53:39.058 INFO RESTORE_INPLACE Forcing in-place mode with a non-default preference path
2018-12-03 22:53:57.374 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/.Spotlight-V100: permission denied
2018-12-03 22:53:57.374 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/.Trashes: permission denied
2018-12-03 22:53:57.374 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/.fseventsd: permission denied
2018-12-03 22:58:24.011 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/data/.DocumentRevisions-V100: permission denied
2018-12-03 22:58:24.011 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/data/.Spotlight-V100: permission denied
2018-12-03 22:58:24.011 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/data/.TemporaryItems: permission denied
2018-12-03 22:58:24.011 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/data/.Trashes: permission denied
2018-12-03 22:58:24.011 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/data/.fseventsd: permission denied
2018-12-03 23:01:53.327 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/media/.DocumentRevisions-V100: permission denied
2018-12-03 23:01:53.327 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/media/.Spotlight-V100: permission denied
2018-12-03 23:01:53.327 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/media/.TemporaryItems: permission denied
2018-12-03 23:01:53.327 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/media/.Trashes: permission denied
2018-12-03 23:01:53.327 WARN LIST_FAILURE Failed to list subdirectory: open /Volumes/pool/media/.fseventsd: permission denied
