Restore: stale symlink can cause out-of-repo write (CWE-59)
Migrating my revisions out of duplicacy and into restic. :slight_smile:
In this case, revision 1 created /repo/etc/resolv.conf which was an absolute symlink resolving outside of the repository. Revision 2 then restored /repo/etc/resolv.conf, which was a regular file. Rather than replace the symlink located at /repo/etc/resolv.conf, duplicacy followed the symlink, overwriting the target (which happened to live outside of the repository). Oops.
(1) Never blindly follow symlinks during restore
(2) Definitely don’t ever write outside of the repository root during a restore
The restore behavior in general surrounding this situation (on-disk object is different type than revision object) is inconsistent at best, just plan buggy at worst. For example, even with -overwrite and -delete, duplicacy will not replace a non-empty on-disk directory with a file during a restore. So in some cases, it’s actually impossible to get duplicacy to restore a repository to a particular revision state.
But for now, it should at least not overwrite non-repository files. :upside_down_face:
