I have to restore a large repository, from a storage. I am running the Duplicacy Ubuntu CLI version 3.0.1.
After several hours, and about one-third of the job done, the restore stops with this error:
Failed to create the file /media/dir1/My documents/dir2/Temp/~$׳…gibberish… ׳“׳™׳” ׳ ׳•׳¡׳₪׳×.doc for in-place writing
I don’t need the files in directory /media/dir1/My documents/dir2/Temp.
I tried to exclude the directory using a filters file, but the exclusion does not work.
How to continue the restore overcoming the error?
Here is the entire session:
user-1@PC-main:/media/user-1/disk-1/dir1$ sudo duplicacy restore -r 3 -overwrite -threads 10 -stats | awk ‘{ ++i ; if (i != 40) { if ( !(/Skipped|Downloaded|Packed|Packing/) ) { print} } else { i=0; print } }’
Repository set to /media/user-1/disk-1/dir1
Storage set to /media/user-1/disk-1/PC-1/PC-1-disk.bkp
Indexing /media/user-1/disk-1/dir1
Parsing filter file /home/user-1/.duplicacy/filters/PC-1/f-PC1-SATA-restore
Loaded 1 include/exclude pattern(s)
snapshot Snapshot-A at revision 3 is encoded in an old version format
Restoring /media/user-1/disk-1/dir1 to revision 3
Downloaded chunk 30 size 9577811, 11.61MB/s 04:00:32 0.1%
Downloaded chunk 72 size 4612421, 14.15MB/s 03:17:06 0.3%
Downloaded chunk 38757 size 6045082, 7.23MB/s 06:22:44 37.4%
The “filters” file contains a single line:
-/media/user-1/disk-1/dir1/My\ Documents/dir2/Temp/
I changed the filter to:
-/media/user-1/disk-1/dir1/My Documents/dir2/Temp/
It didn’t help
