I’m using Backblaze B2 with:
$ duplicacy backup -stats -threads 16 -limit-rate 800
With a fresh B2 bucket, on the very first run of the backup command, it failed after uploading about 3900 chunks:
Uploaded chunk 3920 size 11244935, 1.19MB/s 21 days 14:34:08 0.8%
Uploaded chunk 3909 size 15300223, 1.19MB/s 21 days 14:54:37 0.8%
Uploaded chunk 3923 size 12382213, 1.19MB/s 21 days 14:48:52 0.8%
Failed to find the path for the chunk <hex here>: Maximum backoff reached
Incomplete snapshot saved to /.../.duplicacy/incomplete
When I run the same backup command again, it gave me this output:
Storage set to b2://...
No previous backup found
Indexing /.../
<some lines about skipping non-regular file that I don't think are relevant>
Incomplete snpashot loaded from /.../.duplicacy/incomplete
Listing all chunks
Skipped 1639 files from previous incomplete backup
Use 16 uploading threads
Skipped chunk 2 size 2298987, 2.19MB/s 11 days 18:04:14 0.0%
Skipped chunk 3 size 2028688, 4.13MB/s 6 days 05:50:38 0.0%
Skipped chunk 4 size 1427268, 5.49MB/s 4 days 16:40:54 0.0%
Skipped chunk 5 size 8982088, 14.05MB/s 1 day 20:00:11 0.0%
Uploaded chunk 12 size 1105465, 645KB/s 40 days 22:22:45 0.0%
Uploaded chunk 14 size 1153988, 664KB/s 39 days 17:50:00 0.0%
Uploaded chunk 7 size 1637334, 520KB/s 50 days 18:01:47 0.0%
It looks like it only skipped 4 chunks total (chunks 2-5) and basically started over from scratch. I don’t think anything in the directory to be backed up actually changed between the two runs, though I’m not 100% sure.
Is this a known limitation? How can I get the resume behavior to avoid re-uploading things? The problem is that I expect my backups to be interrupted every once in a while (due to connectivity loss, power interruption, etc), and if it starts over every time, I’ll never actually be able to finish a backup.
Thanks for any help!
