I tried searching the forums a bit for this, but can someone clarify:
With encrypted storage:
If I started a backup with ID “OriginalBackup” on machine1 but I only finished about 80% of the full backup upload, stopped it & shut down this machine.
Resumed backup of the same data on machine2 to the same storage:
- Is it important that I use the same ID “OriginalBackup”? Because I’ve never completed a full backup of that ID & I’d like to change it, but not re-upload 80% of the chunks.
- Does it matter that the directory structure of the data is slightly different, even if the files are the same? I’m thinking no, because it’ll just use deduplication & that doesn’t care about directory structure.
So in short:
- Can I resume backup on machine2 with new ID “NewBackup” towards the storage and it’ll just skip 80% of the chunks and continue?
- Or do I need to stick to the original backup ID “OriginalBackup” finish the full backup and THEN I can adjust backup ID?
