Hi All,
I’m starting backup my data using duplicacy and B2 backend. I’m also planning to periodically “verify” my backups by, say, randomly downloading a few files from recent revisions to a temporary local workspace, compare their SHAs or MD5SUMs to my original local sources (from which it was uploaded in the first place). I intend to automate this process so that if there is a mismatch noted, I’ll be notified via email of some sorts…
For this to seamlessly work, I’m thinking the automated script would be work similar to this post: Restore to a different folder or computer . However, what I’d like is to not re-enter the password, B2 access keys, etc every time the automated script does its download. I could store these credentials in environmental variables too. But, I was wondering if there is a way to “reuse” my existing credentials from my existing source repository for this automated script.
Say, I have a source repo in a directory called “/path/to/source” and all the preferences, key ring etc have been stored in “/path/to/duplicacy-config” folder (so that the .duplicacy folders don’t mingle with the repo). If I intend to restore only some files to a different folder say “/path/to/backuptest”, I’m wondering if I can point duplicacy at the “/path/to/duplicacy-config” folder and get things to work? Can I merely make a copy of the “/path/to/duplicacy-config” folder and then re-use it? Any other steps I’m missing…?
This post also seems related to Restore has no option to pick destination, but I couldn’t tell if version 2.1.1 has the option to restore to a different folder (in my example, use “/path/to/duplicacy-config” but restore not to the usual repo, but a different repo folder…
). I did see this topic:
