Hi all,
I use Duplicacy-Web with Google Cloud Drive as my main backup storage and Backblaze B2 as a copy storage. However GCD really is a bit slow on retrieval, so I was thinking, of setting this up a bit differently. While I know that one can (somehow) configure Cloudflare to use with B2 to avoid B2’s egress fees, getting this to work would take some time (even if I knew what I was doing).
Since the backup is small in size (currently ca. 40GB), I created a 3rd storage locally on my NAS and copied the GCD backup to that storage.
So right now the setup is::
Data -> backup -> GCD
-> copy -> B2
-> copy -> Local NAS
What I want to change this to is:
Data -> backup -> Local NAS
-> copy -> B2
-> copy -> GCD
Since all three storages have the same versions, same amount of chunks, same pruning schedule, I would assume that it is safe to simply make that change.
But I’d like to get some feedback, whether this is indeed safe or if I have overlooked something.
Thanks in advance for any help on the matter,
Bernhard
