On Windows, is it possible to run duplicacy with a special command so that it is minimized in tray ?
If you close the main window, Duplicacy will remain running in the background while the tray icon will stay there. Is this what you want?
No, I’d like to run duplicacy GUI when I open a session to have a tray icon. Without needing to close the duplicacy’s window opened after opening a session.
It is not possible with the current version, but I can add an option for this feature in the next GUI version.
I’d like to see this also.
I love that Duplicacy can run in the background. I don’t need to see the main GUI each time I login to the system. Would love to see this feature
I’ll add this feature to the beta build of version 2.1.0.
