Hello, I have a Duplicacy backup set to run on a schedule (in the schedules tab). The schedule is set to run every day but I’ve been having to launch it manually. Why is the schedule not working? It says next run is in 2:21:25 but when the time comes and goes, the last backup still shows n days ago. I know that data has changed in the source as well, if that matters.
Update: Clicking the play button on the backup does work but the schedule fails.
I found this in the logs
023/11/21 17:07:07 Running /home/duplicacy/.duplicacy-web/bin/duplicacy_linux_x64_3.1.0 [-log backup -storage pumbaa-bkup -threads 4 -stats]
2023/11/21 17:07:07 Set current working directory to /cache/localhost/3
2023/11/21 17:07:14 Schedule Daily_Backups next run time: 2023-1122 14:27
2023/11/21 23:20:44 Failed to get the value from the keyring: keyring/dbus: Error connecting to dbus session, not registering SecretService provider: exec: “dbus-launch”: execu
table file not found in $PATH
2023/11/21 23:20:44 Failed to decrypt the testing data using the password from KeyChain/Keyring: crypto/aes: invalid key size 0
2023/11/21 23:20:44 Temporary directory set to /cache
2023/11/21 23:20:44 Schedule Check next run time: 2023-1122 00:33
2023/11/21 23:20:44 Schedule Daily_Backups next run time: 2023-1122 14:27
2023/11/21 23:20:44 Duplicacy Web Edition 1.7.2 (1B2557)
2023/11/21 23:20:45 Duplicacy CLI 3.1.0
2023/11/22 00:33:01 Skipping schedule Check at time 2023-1122 00:33 as no encryption password has been provided
Thanks
