Hello,
Could someone help me to resolve an issue?
I’m testing duplicacy with this script: duplicacy-utils/backup.ps1 at master · TheBestPessimist/duplicacy-utils · GitHub
It works as it should. However when running the prune command, it creates a file in the directory of the log and appends the results of the execution of the command to the backup command log.
In detail:
.duplicacy/logs contains the folder “2018-05-08 Tuesday” with the file “backup-log 2018-05-08 22-41-37_636614160976437318.log”.
It displays the log about “Now executting duplicacy.exe -log backup -stats -threads 10 -vss” and “Now executting duplicacy.exe -log prune -keep 0:90”
.duplicacy/logs contains besides the above folder also the file “prune-log-20180508-224141” which is empty. This is “normal” because the content is added to the file “backup-log 2018-05-08 22-41-37_636614160976437318.log”.
