I have setup 13 backups configured, and a local storage using SFTP to a NAS (currently 2.87TB).
I did my initial backup a few days ago, and then for some I did a second backup. I then ran a check. The check worked fine:
Options: [-log check -storage local -a -tabular]
2019-08-11 07:28:27.693 INFO STORAGE_SET Storage set to sftp://backup@mynas.local//share/CACHEDEV1_DATA/duplicacy
2019-08-11 07:28:28.149 INFO SNAPSHOT_CHECK Listing all chunks
2019-08-11 07:28:53.698 INFO SNAPSHOT_CHECK 13 snapshots and 19 revisions
2019-08-11 07:28:53.706 INFO SNAPSHOT_CHECK Total chunk size is 2671G in 564597 chunks
2019-08-11 07:28:53.795 INFO SNAPSHOT_CHECK All chunks referenced by snapshot appdata at revision 1 exist
2019-08-11 07:28:53.815 INFO SNAPSHOT_CHECK All chunks referenced by snapshot aaaaaa at revision 1 exist
2019-08-11 07:28:53.834 INFO SNAPSHOT_CHECK All chunks referenced by snapshot aaaaaa at revision 2 exist
2019-08-11 07:28:53.840 INFO SNAPSHOT_CHECK All chunks referenced by snapshot bbbbbb at revision 1 exist
2019-08-11 07:28:53.845 INFO SNAPSHOT_CHECK All chunks referenced by snapshot bbbbbb at revision 2 exist
2019-08-11 07:28:54.057 INFO SNAPSHOT_CHECK All chunks referenced by snapshot cccccc at revision 1 exist
2019-08-11 07:28:54.096 INFO SNAPSHOT_CHECK All chunks referenced by snapshot books at revision 1 exist
2019-08-11 07:28:54.140 INFO SNAPSHOT_CHECK All chunks referenced by snapshot install at revision 1 exist
2019-08-11 07:28:54.289 INFO SNAPSHOT_CHECK All chunks referenced by snapshot nvr at revision 1 exist
2019-08-11 07:28:54.290 INFO SNAPSHOT_CHECK All chunks referenced by snapshot dddddd at revision 1 exist
2019-08-11 07:28:54.290 INFO SNAPSHOT_CHECK All chunks referenced by snapshot dddddd at revision 2 exist
2019-08-11 07:28:54.291 INFO SNAPSHOT_CHECK All chunks referenced by snapshot eeeeee at revision 1 exist
2019-08-11 07:28:54.291 INFO SNAPSHOT_CHECK All chunks referenced by snapshot eeeeee at revision 2 exist
2019-08-11 07:28:54.328 INFO SNAPSHOT_CHECK All chunks referenced by snapshot ffffff at revision 1 exist
2019-08-11 07:28:54.368 INFO SNAPSHOT_CHECK All chunks referenced by snapshot ffffff at revision 2 exist
2019-08-11 07:28:54.368 INFO SNAPSHOT_CHECK All chunks referenced by snapshot gggggg at revision 1 exist
2019-08-11 07:28:54.368 INFO SNAPSHOT_CHECK All chunks referenced by snapshot gggggg at revision 2 exist
2019-08-11 07:28:54.453 INFO SNAPSHOT_CHECK All chunks referenced by snapshot music at revision 1 exist
2019-08-11 07:28:56.082 INFO SNAPSHOT_CHECK All chunks referenced by snapshot photos at revision 1 exist
2019-08-11 07:29:00.312 INFO SNAPSHOT_CHECK
bbbbbb | 1 | @ 2019-08-05 05:31 -hash | 4437 | 9,800M | 1617 | 7,473M | 3 | 586K | 1617 | 7,473M |
bbbbbb | 2 | @ 2019-08-05 15:27 | 4422 | 9,800M | 1618 | 7,473M | 4 | 773K | 4 | 773K |
bbbbbb | all | | | | 1621 | 7,474M | 1381 | 6,254M | | |
cccccc | 1 | @ 2019-08-05 05:38 -hash | 11064 | 293,700M | 55988 | 276,496M | 54837 | 271,044M | 55988 | 276,496M |
cccccc | all | | | | 55988 | 276,496M | 54837 | 271,044M | | |
books | 1 | @ 2019-08-05 10:14 -hash | 20497 | 68,148M | 12913 | 60,424M | 12878 | 60,305M | 12913 | 60,424M |
books | all | | | | 12913 | 60,424M | 12878 | 60,305M | | |
install | 1 | @ 2019-08-05 11:25 -hash | 3365 | 76,352M | 13978 | 66,502M | 13886 | 66,076M | 13978 | 66,502M |
install | all | | | | 13978 | 66,502M | 13886 | 66,076M | | |
nvr | 1 | @ 2019-08-05 15:27 -hash | 3539 | 162,724M | 33165 | 163,243M | 33165 | 163,243M | 33165 | 163,243M |
nvr | all | | | | 33165 | 163,243M | 33165 | 163,243M | | |
appdata | 1 | @ 2019-08-08 02:41 -hash | 305454 | 80,634M | 10156 | 42,059M | 10052 | 41,626M | 10156 | 42,059M |
appdata | all | | | | 10156 | 42,059M | 10052 | 41,626M | | |
aaaaaa | 1 | @ 2019-08-05 02:51 -hash | 43176 | 29,628M | 5890 | 26,809M | 9 | 4,575K | 5890 | 26,809M |
aaaaaa | 2 | @ 2019-08-05 11:24 | 43122 | 29,629M | 5886 | 26,809M | 5 | 4,668K | 5 | 4,668K |
aaaaaa | all | | | | 5895 | 26,813M | 4937 | 22,259M | | |
eeeeee | 1 | @ 2019-08-05 02:50 -hash | 2754 | 557,144K | 75 | 288,450K | 3 | 282K | 75 | 288,450K |
eeeeee | 2 | @ 2019-08-05 11:25 | 2753 | 559,082K | 76 | 289,497K | 4 | 1,329K | 4 | 1,329K |
eeeeee | all | | | | 79 | 289,779K | 75 | 277,032K | | |
ffffff | 1 | @ 2019-08-05 04:23 -hash | 14463 | 66,835M | 13383 | 64,933M | 2 | 1,557K | 13383 | 64,933M |
ffffff | 2 | @ 2019-08-05 12:36 | 14461 | 66,835M | 13382 | 64,933M | 1 | 1,559K | 1 | 1,559K |
ffffff | all | | | | 13384 | 64,934M | 7405 | 36,430M | | |
gggggg | 1 | @ 2019-08-05 05:34 -hash | 99 | 52,709K | 14 | 43,129K | 1 | 12K | 14 | 43,129K |
gggggg | 2 | @ 2019-08-05 05:38 | 99 | 52,709K | 14 | 43,129K | 1 | 12K | 1 | 12K |
gggggg | all | | | | 15 | 43,141K | 15 | 43,141K | | |
music | 1 | @ 2019-08-05 12:36 -hash | 23163 | 149,283M | 29318 | 132,946M | 29284 | 132,829M | 29318 | 132,946M |
music | all | | | | 29318 | 132,946M | 29284 | 132,829M | | |
photos | 1 | @ 2019-08-05 18:33 -hash | 167194 | 1923G | 384802 | 1834G | 376577 | 1795G | 384802 | 1834G |
photos | all | | | | 384802 | 1834G | 376577 | 1795G | | |
dddddd | 1 | @ 2019-08-05 02:48 -hash | 400 | 256,483K | 59 | 220,747K | 1 | 50K | 59 | 220,747K |
dddddd | 2 | @ 2019-08-05 12:36 | 400 | 256,483K | 59 | 220,747K | 1 | 50K | 1 | 50K |
dddddd | all | | | | 60 | 220,797K | 60 | 220,797K | | |
Now whenever I do another backup, the backups run fine, but a check after reports missing chunks.
2019-08-11 07:40:20.755 INFO STORAGE_SET Storage set to sftp://backup@mynas.local//share/CACHEDEV1_DATA/duplicacy
2019-08-11 07:40:21.075 INFO SNAPSHOT_CHECK Listing all chunks
2019-08-11 07:41:48.439 INFO SNAPSHOT_CHECK 13 snapshots and 32 revisions
2019-08-11 07:41:48.447 INFO SNAPSHOT_CHECK Total chunk size is 2671G in 564694 chunks
2019-08-11 07:41:48.485 INFO SNAPSHOT_CHECK All chunks referenced by snapshot ffffff at revision 1 exist
2019-08-11 07:41:48.538 INFO SNAPSHOT_CHECK All chunks referenced by snapshot ffffff at revision 2 exist
2019-08-11 07:41:48.563 FATAL DOWNLOAD_CHUNK Chunk 91f11084ff78f06ec9fb14660b024817ee7c6de41e4dd44aa387ffb2da08fe99 can't be found
I went through each snapshot in the storage folder and deleted the one from today as recommended here. I did this individually for each backup and then ran the check again, and each time got similar missing chunk errors until I had removed all of todays snapshots. Eventually the check worked OK.
I then ran the backups again - this ran fairly quickly as most of the chunks would have already existed. The backups all succeeded, but afterwards the check failed with the same problem with missing chunks.
A few points:
- the prune logs do not show any files being pruned (nothing is old enough yet)
- no other clients are using the backup repository (have never configured any)
- I’m using duplicacy web edition in docker, running under unraid
- the NAS is a QNAP, and I’m accessing it on a local LAN using SFTP.
- the initial backup was actually done using SMB (mapped to a local folder in unraid and passed through to the docker container). I then deleted the storage and added it back using the same name and SFTP.
- my logs have been modified to remove personal information (backup names)
I have to admit I’m a bit concerned about the safety of using duplicacy ongoing. I hope it’s something specific to my setup and easily fixed as I like it a lot!
Any suggestions appreciated!
